NotJustPiercys
Aug 21, 2017Aspirant
ReadyNAS NV+ RND4000 000D-A201-3ECf stuck after PSU replacement
We had a power outage the other night. When the power returned my four-disc X-RAID ReadyNAS NV+ (not V2) was completely dead and would not power up. I ordered a replacement power supply and repla...
NotJustPiercys
Thanks Stephen!
Tried that - no change.
With all four discs removed, half an hour after powering up again (the power up button does work to power up, just not to power down):
- The front panel LCD message still shows the previous message ‘Booting Please wait...’
- None of the four disc lamps has lit up.
- The blue power lamp continues to flash but won’t power the ReadyNAS down when pressed.
- RAIDar_6.3.0 again returns ‘RAIDar could not find any NETGEAR storage on your network. Check that your storage device is powered on and connected correctly. For more help, visit http://my.netgear.com.’
I wish I had better news, but many thanks for your help!
Cheers
Tom
Aug 21, 2017Guru - Experienced User
It sounds like something on the system board got damaged when the PSU failed.
- NotJustPiercysAug 21, 2017Aspirant
StephenB wrote:It sounds like something on the system board got damaged when the PSU failed.
Yup, it certainly does. I'll look out for a replacement case/housing in the usual places and see if we can put the jigsaw back together..
Again, many thanks for your help - it really is appreciated. Both the practical and the moral help...
Cheers
Tom
