BrantRaven
Jul 30, 2018Aspirant
ReadyNAS NV+ (RND4000v3) Device not powering on. Looking for help and advice.
Hello Community,
I own a ReadyNAS NV+ (RND4000v3).
Has worked find since purchasing it...worked yesterday...today I push the ON button and nothing. No idea what has happened. I suspect the power ...
- Aug 05, 2018
Marc_V
Jul 30, 2018NETGEAR Employee Retired
Hi BrantRaven
Welcome to the Community!
If you have tried changing Power cord or outlet and not even the LCD/LED is not lighting up, most probably the PSU is already busted. Which is a normal issue with the unit.
Here is a thread that will answer your question regarding replacing the PSU. You may also want to purchase a used NV+ which is working fine, but you have to make sure you have the correct NV+ version.
How to tell your NV+ version is important
IMO, It is better to upgrade your ReadyNAS System to an OS 6 unit like the RN400 series or other line, NV+ is too old to say.
Hope this reply helps!
Regards
BrantRaven
Aug 01, 2018Aspirant
Thank you for the welcome Marc_V.
At this point I am trying to understand how to modify a regular ATX supply in order to a. confirm that the unit can power on and b. extract all the data. Do you know of a clear guide that gives these modifications?
Brant
- Marc_VAug 01, 2018NETGEAR Employee Retired
Hi BrantRaven
This might help https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/Power-supply-pin-modification-for-ReadyNas-NV/m-p/1581397#M17051 :)
Regards
- BrantRavenAug 01, 2018Aspirant
- StephenBAug 01, 2018Guru - Experienced User
The pinout you need is shown on the right diagram here: https://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
You'll need an extender cable anyway, so consider making the changes in the extender cable.
Thank you for the reply.
Im not sure what you mean by Extender Cable? Do you mean a cable to extend the ATX connector? Where would I get one of those?
Brant
OK...Have read through all the material and I think I get what is going on and what is needed.
My only question now is...do I simply remove the -12V and -5V lines and I am ready to go....or do I need to replace these with +12V lines as per the diagram??
Brant
