BrantRaven
Jul 30, 2018Aspirant
ReadyNAS NV+ (RND4000v3) Device not powering on. Looking for help and advice.
Hello Community,
I own a ReadyNAS NV+ (RND4000v3).
Has worked find since purchasing it...worked yesterday...today I push the ON button and nothing. No idea what has happened. I suspect the power ...
- Aug 05, 2018
BrantRaven
Aug 01, 2018Aspirant
OK...Have read through all the material and I think I get what is going on and what is needed.
My only question now is...do I simply remove the -12V and -5V lines and I am ready to go....or do I need to replace these with +12V lines as per the diagram??
Brant
Marc_V
Aug 05, 2018NETGEAR Employee Retired
- BrantRavenAug 05, 2018Aspirant
Thank you for this community and the information you provided.
I managed to modify a regular ATX supply, removing the blue and white cables from the 20-pin ATX power addapter and replacing those with 2 yellow cables I had removed from a 4-pin adapter.
I have now managed to get my NAS device up an running an am pulling data off it as we speak.
Thank you again for the great help.
Brant
