Astiran
Feb 04, 2017Aspirant
Readynas NV+ SLOW TRANSFER SPEED
ReadyNAS NV+ RAIDiator 4.1.15 4x 1TB WD Green Raid 5 PC is gigbit, but my transfer speed maxes out at 12MB/sec. I've tried connecting directly to the NAS, and no change in speed. Jumbo frames...
JennC
Feb 06, 2017NETGEAR Employee Retired
Hello Astiran,
Do you have any add-ons and/or backup job running at the same time? Also, how do you transfer files?
This link might help.
Welcome to the community!
- AstiranFeb 06, 2017Aspirant
No backup jobs, and no addons. I transfer using CIFS. I've also used NAStester and had the same results. I've tried with jumo frames enabled, and disabled on both my pc and readynas.
- StephenBFeb 06, 2017Guru - Experienced User
Can you use this guide to check block size and 4K alignment? http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-sparc-readynas/
NAStester uses CIFS btw.
