Astiran
Feb 04, 2017Aspirant
Readynas NV+ SLOW TRANSFER SPEED
ReadyNAS NV+ RAIDiator 4.1.15 4x 1TB WD Green Raid 5 PC is gigbit, but my transfer speed maxes out at 12MB/sec. I've tried connecting directly to the NAS, and no change in speed. Jumbo frames...
JennC
Feb 06, 2017NETGEAR Employee Retired
Hello Astiran,
Do you have any add-ons and/or backup job running at the same time? Also, how do you transfer files?
This link might help.
Welcome to the community!
Astiran
Feb 06, 2017Aspirant
No backup jobs, and no addons. I transfer using CIFS. I've also used NAStester and had the same results. I've tried with jumo frames enabled, and disabled on both my pc and readynas.
- StephenBFeb 06, 2017Guru - Experienced User
Can you use this guide to check block size and 4K alignment? http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-sparc-readynas/
NAStester uses CIFS btw.
