Astiran
Feb 04, 2017Aspirant
Readynas NV+ SLOW TRANSFER SPEED
ReadyNAS NV+ RAIDiator 4.1.15 4x 1TB WD Green Raid 5 PC is gigbit, but my transfer speed maxes out at 12MB/sec. I've tried connecting directly to the NAS, and no change in speed. Jumbo frames...
Feb 07, 2017Guru - Experienced User
Astiran wrote:
I didn't realize that it doesn't actually use raid 5. I do need the redundancy to protect my data,
It has the same redundancy as RAID-5. The only difference is the organization of the parity blocks. RAID-5 distributes the parity blocks over all the disks, RAID-4 puts them all on a dedicated parity disk. Distributing the blocks evens out the I/O across the disks. Your NV+ has hardware acceleration for RAID, and I think that is why it uses RAID-4.
Newer NAS (NV+ v2, ultra, pro, all OS 6 NAS) use RAID-5.
Astiran wrote:
is there a difference between the raid 5 and xraid?
XRAID is built on top of standard RAID. In your NAS it will convert from single disk->raid 1->raid 4 as you add drives. If you upgrade all four drives, it will also expand the volume automatically. As you likely know, the NV+ can't handle drives larger than 2 TB.
On newer NAS, it can also handle drives of different sizes, and (if you want it) dual redundancy.
Astiran
Feb 07, 2017Aspirant
Found this in my partition logs.
WARNING: GPT (GUID Partition Table) detected on '/dev/hde'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md2 doesn't contain a valid partition table
Disk /dev/hdc: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 5144607 524288 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary.
/dev/hdc3 5144608 1953508815 974182104 fd Linux raid autodetect
Partition 3 does not end on cylinder boundary.
Disk /dev/hde: 1000.2 GB, 1000204886016 bytes
- StephenBFeb 09, 2017Guru - Experienced User
This is normal, so don't worry about it. I don't know why Netgear continues to run fdisk.
- AstiranFeb 09, 2017Aspirant
Still no luck. Backed up all of my data, did a complete reset, formatted to raid 5, still getting about 10MB/s write speeds. I'm thinking when I'm in the market for a new nas I might just avoid netgear. I used to have a WD Sharespace and it was faster than this, even though it was quite a bit older.
- StephenBFeb 10, 2017Guru - Experienced User
Your NV+ v1's hardware design goes back to 2006 - I don't think WD was building NAS back then. It's been end-of-life for over 5 years. A new ReadyNAS can delivers 50-100+ MB/sec on a gigabit network (depending on which model you purchase).
That said, 10 MB/sec is slower than it should be. Did you look at the ethernet stats for packet loss?
