Astiran
Feb 04, 2017Aspirant
Readynas NV+ SLOW TRANSFER SPEED
ReadyNAS NV+ RAIDiator 4.1.15 4x 1TB WD Green Raid 5 PC is gigbit, but my transfer speed maxes out at 12MB/sec. I've tried connecting directly to the NAS, and no change in speed. Jumbo frames...
Astiran
Feb 13, 2017Aspirant
I did check it yesterday but forgot to post back here. Here's the current results:
VLAN tags 19
TCP Retransmits 2
Unrecovered TCP Retransmits 1
Everything else is still showing 0
- StephenBFeb 13, 2017Guru - Experienced User
Well, something must be sending them, but I can't think of an easy way to isolate it.
I don't think the TCP retransmits are enough to explain the slow speeds, and we aren't seeing any sign of packet loss or cabling issues in your stats.
Are you doing all the testing from a single PC? If you have a second one, it might be worth seeing it gives the same results.
