andysbikeclinic
Aug 19, 2019Aspirant
ReadyNAS NV+ stuck on "Booting Please wait"
Hi, As per the title, my ReadyNAS NV+ will no longer boot. The display says 'Booting Please Wait...' but never progresses beyond this point. I can not turn the unit off using the button on the fr...
andysbikeclinic
When booting with the disks removed, I get the following message.
'Booting...ERR: No disks'
The blue power light is flashing on and off.
The disk lights themselves show the following pattern; number 2 disk light lights up and then disappears, then all four disk lights flash and disappear. This is repeated over and over.
Aug 19, 2019Guru - Experienced User
andysbikeclinic wrote:
It was bought in July 2011, and the power goes straight in the back of the unit.
So it is a v1.
That is normal. Is RAIDar giving you any more information (for instance the firmware version).
Probably the next step is to test the disks in a Windows PC. Use Lifeguard for Western Digital; Seatools for Seagate.
If you have a spare disk (2 TB or smaller) you can try doing a factory install with just that disk in place. If that works, try testing each of the NAS disk bays by
- powering down
- move the disk to the next slot
- power up and confirm that the NAS boots.
- andysbikeclinicAug 19, 2019Aspirant
No RAIDar doesn't give me any information about firmware version.
I will download the disk diagnostic tools and see how far I get. I have 2 x Seagate Barracuda drives, and 2 x Samsung drives. Can I use Seagate's ESwin program on the Samsung drives do you know? A Google search suggests so. And is it the Windows version of SeaTools I need for the Seagate Barracuda drives?
Thanks for your ongoing help.
- StephenBAug 19, 2019Guru - Experienced User
I don't own any Samsung drives, so I don't have any direct experience there. The Windows version of SeaTools is what you want for the Barracudas.
