andysbikeclinic
Aug 19, 2019Aspirant
ReadyNAS NV+ stuck on "Booting Please wait"
Hi, As per the title, my ReadyNAS NV+ will no longer boot. The display says 'Booting Please Wait...' but never progresses beyond this point. I can not turn the unit off using the button on the fr...
andysbikeclinic
Aug 21, 2019Aspirant
Hi Marc,
Assuming I can find one disk that is OK, can I use recovery software you mentioned? Do these programs run on Windows PC OK?
Thanks again.
Aug 21, 2019Guru - Experienced User
You'll need three (and ideally all four). You can use use USB adapter/docks, or a multi-disk enclosure to connect them to the PC.
If disks are marginal, you could clone them, and recover from the clones. Cloning also ensures that you don't accidentally do more damage to the file system in your recovery efforts.
Yes. FWIW, R-linux for Windows is quite a bit cheaper. ReclaiMe supports the BTRFS file system - which is used by the new OS-6 ReadyNAS, but not by your old NV+ (which uses ext).
- andysbikeclinicAug 21, 2019Aspirant
Can I at least test the 4 disks one at a time within a Windows 10 PC? Sorry for all the questions, but as a home user, it's a bit daunting buying PC kit in order to assess any potential damage to the disks.
- StephenBAug 21, 2019Guru - Experienced User
Yes. Windows won't recognize the disk format, so they won't show up in file explorer. But you will see them in the Windows disk manager. Test them with Lifeguard for Western Digital; Seatools for Seagate.
Power down the NAS before removing disks, and label them by slot number as you remove them. Put them back in place before you power up the NAS.
- SandsharkAug 23, 2019Sensei
Seatools will run enough of a diagnostic on your non-Seagate drives to know if they are the problem.
