rsbeck
May 17, 2017Aspirant
ReadyNAS NV+ v1 Replaced Drive, Won't Boot
Hello, I have the ReadyNas NV+ v1. It came with four 750Gig drives. I saw a warning message on the front of the unit that one of my drives was experiencing errors, so I removed drive #1, the un...
JennC
May 18, 2017NETGEAR Employee Retired
Hello rsbeck
Can you still get to the files after removing the new disk that you just inserted? Do you have full backup of the data?
When replacing the disk that has gone faulty, it has to be of the same size of the faulty one, unless you are going to expand the volume.
What's the current firmware version of the NAS?
- rsbeckMay 18, 2017Aspirant
Hi JennC,
Thanks for the reply!
No, removing the new disk has no effect. It does not return to its previous state where it was working perfectly. In fact, I also tried removing all of the disks, just to see if I could get it to do something different, but I keep getting the same result. I reboot by unplugging, plugging then powering up by pressing the power button. The green lights on the front of the unit corresponding to drives #1 and #3 light up, even when there are no drives inside. The lower window on the front of the unit stays dark and now, in addition, I hear a grinding sound, which is a new development. And after booting up, no matter how long I press the power button, it will not power down unless I unplug. Cant get to the files. It doesnt show up on the network.
I thought it was okay to go up in size with the new drive, but I just wouldnt get the additional space until I replaced all of the drives with the same increased capacity. Is that wrong? I'm not sure of the current firmware, but it was last updated about two years ago. Can't get into it to see what firmware I'm currently running.
I dont have any back-up of the data. It is full of CD's I have ripped and I stilll have all of the CD's. So, if I lose the data on the NAS, it will be a pain to rip the entire 2,500 CD collection again, but at least I have the data.
Thanks for your help,
Rob
- SandsharkMay 18, 2017Sensei
That's the code for "Boot loader fails to locate valid RAIDiator image, TFTP or USB OS image recovery required." You need to do a USB OS recovery. For more LED codes, see here: ReadyNAS LED Language.
Now, why that happened concurrent with replacing a drive is another question. Maybe just coincidence, but how likely is that?
- rsbeckMay 28, 2017Aspirant
How do I do a USB OS recovery?
