rsbeck
May 17, 2017Aspirant
ReadyNAS NV+ v1 Replaced Drive, Won't Boot
Hello, I have the ReadyNas NV+ v1. It came with four 750Gig drives. I saw a warning message on the front of the unit that one of my drives was experiencing errors, so I removed drive #1, the un...
dmahon1
May 29, 2017Aspirant
I don't know why you have the error that you have, and good luck sorting it out, but I thought the correct procedure for doing what you wanted would have been to put the new disk (same size or larger) into slot one WITHOUT powering down.
- StephenBMay 29, 2017Guru - Experienced User
dmahon1 wrote:
... I thought the correct procedure for doing what you wanted would have been to put the new disk (same size or larger) into slot one WITHOUT powering down.
I always recommend hot-insertion, since that gives the NAS a clear indication that a drive is removed and the new one inserted.
But installing a blank disk with the NAS powered down also works.
