rsbeck
May 17, 2017Aspirant
ReadyNAS NV+ v1 Replaced Drive, Won't Boot
Hello, I have the ReadyNas NV+ v1. It came with four 750Gig drives. I saw a warning message on the front of the unit that one of my drives was experiencing errors, so I removed drive #1, the un...
rsbeck
May 29, 2017Aspirant
Hi Stephen,
Thanks for the reply. I'm going to need more help as I am inexperienced in this stuff. Can you explain this paragraph to me?
"If you are experiencing boot problems and TFTP Boot Recovery and write that image to the USB flash device. To write the image on a Windows PC, you'll need to use Rawrite32. Make sure to click the Eject button after the write is complete. On Macs and Linux systems, you'll need to 'dd' to write the image to the flash device."
I have Mac. I don't know what image to write to the USB Flashdrive or how to write it. I also don't know what dd means.
Thanks for your help!
Rob
Rob
Sandshark
May 29, 2017Sensei
Don't feel bad about not understanding it. It makes no sense. Quite obviously, there is something missing from that and the TFTP Boot Recovery page as well.
"If you are experiencing boot problems and TFTP Boot Recovery (some important stuff is missing here) and write that image to the USB flash device. To write the image on a Windows PC, you'll need to use Rawrite32. Make sure to click the Eject button after the write is complete. On Macs and Linux systems, you'll need to 'dd' to write the image to the flash device."
- SandsharkJun 03, 2017Sensei
Hmmm, nobody chimed in with the missing text. I never had a need to do a USB recovery on my NV's, so don't know the process. And I don't want to just guess (though I have an idea what's needed). Hopefully mdgm-ntgr or one of the other mods will pick up on this and fill in the blanks.
