rsbeck
May 17, 2017Aspirant
ReadyNAS NV+ v1 Replaced Drive, Won't Boot
Hello, I have the ReadyNas NV+ v1. It came with four 750Gig drives. I saw a warning message on the front of the unit that one of my drives was experiencing errors, so I removed drive #1, the un...
kohdee
Jun 20, 2017Administrator
It probably was not necessary to shut down the chassis to insert the new drive.
The only way I'll know what is going on is for it to be in tech support mode so I can review the system, or a set of logs if the web interface comes up. Otherwise, I would only be speculating, and that is not good to do with your device.
Have you sent us your logs yet?
