Kaleem
Jan 06, 2014Aspirant
ReadyNas NV+ v2 - Corrupt root & ERR: Could not mount root..
Hi, I'm attempting to install for the first time 4 x 3TB Seagate Drives in the ReadyNas NV+ v2 unit, and experiencing the following: 1) ReadyNas Unit is displaying "ERR: Could not mount root RAI...
vandermerwe
Jan 06, 2014Master
Have you followed these steps exactly?
To access the boot menu:
1. Power off your unit.
2. Using a straightened paper clip, press and hold the Reset button.
3. Press the Power button to power on the unit.
4. Continue to press the Reset button until the status display screen shows a boot menu message.
5. Press the Backup button to scroll through boot mode options. The status display screen shows the current boot mode option.
6. When the status display screen shows the boot mode you need, press and release Reset button to confirm your boot menu selection.
The system boots in the selected boot mode.
What happens when you do the steps above?
Where and when did you get the unit?
