NasipovFarit
Aug 15, 2016Aspirant
ReadyNAS nv+ v2 - factory reset after every restart, disks locked, erasing not finished after 6 days
At first I need to say that I read threads concerning same symptoms but still have no solution.
History:
Have ReadyNAS nv+ v2 worked well 6 years. Month ago got alert and decide to change dis...
- Aug 15, 2016
So you have the v2 (runs RAIDiator 5.3.x)
The disks can be unlocked using hdparm e.g.
# hdparm --security-unlock NETGEAR /dev/sda
# hdparm --security-disable NETGEAR /dev/sda
mdgm-ntgr
Aug 15, 2016NETGEAR Employee Retired
NasipovFarit
Honestly, I don't catch exactly what I should to do with commands you suggest to apply.
How to switch into hdparm in ReadyNAS? Can you just suggest any manual for noobie?
- mdgm-ntgrAug 15, 2016NETGEAR Employee Retired
Maybe it would be easier if I did it then.
I have sent you a PM.
- mdgm-ntgrAug 17, 2016NETGEAR Employee Retired
Typically if disks are locked this is caused by doing a factory default, choosing the secure erase option and aborting the secure erase by powering off the system before it completes.
If you want to use the disks elsewhere you could hook them up to your PC, delete the partitions off them and format them.
- NasipovFaritAug 17, 2016Aspirant
Thank you very much!
Your help was priceless and I'm very grateful for your advices!
