NasipovFarit's avatar
NasipovFarit
ReadyNAS nv+ v2 - factory reset after every restart, disks locked, erasing not finished after 6 days
At first I need to say that I read threads concerning same symptoms but still have no solution.   History: Have ReadyNAS nv+ v2 worked well 6 years. Month ago got alert and decide to change dis...
  • mdgm-ntgr's avatar
    Aug 15, 2016
    So you have the v2 (runs RAIDiator 5.3.x)
    The disks can be unlocked using hdparm e.g.
    # hdparm --security-unlock NETGEAR /dev/sda
    # hdparm --security-disable NETGEAR /dev/sda
ProSupport for Business
