callingrohit
Sep 18, 2018Aspirant
ReadyNAS NV+ v2 - hdd freezes and lost connection
Hi Community
I have a ReadyNAS NV+ v2 with each bay filled with 2TB WD HDD. I have just come across a situation wherein the NAS or my shared folders are no more visible [IP connectivity is ther...
- Sep 21, 2018
The capacity rule for XRAID is "sum the disks and subtract the largest". That's the best that can be done - it's impossible to do better and still provide single redundancy. So as bedlam1 says you need to upgrade two drives to gain space.
I'm not 100% certain, but I believe the expansion limits in the ReadyNAS Pro/Ultra also apply to the v2. Those limits are
- a volume cannot expand over the 16 TiB size ceiling
- a volume cannot expand more that 8 TiB from it's starting point.
An example of the second limit: Let's say your last factory install started with a single 2 TB drive, and you then added the others. Your starting point would be 2 TB (1.73 TiB). Your upgrade ceiling would be 10.73 TiB. You can expand to 2 TB + 3x4TB (10 TB volume size). But if you try to upgrade the final drive to 4 TB you'd exceed the ceiling (12 TB -> 10.9 TiB). So that upgrade would fail.
It's not possible for you to hit either limit in this upgrade, (since your total volume size will be 8 TB), but you might keep it in mind if you expand further. If you were to hit the second limit, the only workaround is to do a factory reset and restore the data from backup.
callingrohit
Sep 19, 2018Aspirant
Thanks Stephen for your reply.
The NAS model is certainly NV+ v2 and confirmed it via the admin WebUI and running firmware 5.3.12 which I'm now planning to upgrade to the 5.3.13.
Raid type I think is the default - X-RAID2.
The current free space is 564 GB out of 5.41TB.
Sep 20, 2018Guru - Experienced User
If you don't have a current backup of your files, then I recommend making one before you proceed.
You might want to wait on upgrading the firmware until you resolve the problem. If it is a filling OS partition, then attempting to upgrade the firmware could brick your NAS.
This isn't a platform I own, so I don't have direct experience with it. You might want to download the full log zip file from the web UI, and ask a Netgear mod to analyze them. A PM (private message) is a reasonable path. Marc_V, JohnCM_S, evan2 are some folks you could ask. BTW, don't post a link to your logs publically. There is some information in them that could compromise privacy.
Another option (if you are the original purchaser) is to use paid support (my.netgear.com). Ask about "per incident" support.
- callingrohitSep 20, 2018Aspirant
Thanks Stephen for your suggestions.
The free space currently sits exactly at 10% and as soon as it goes <10%, the performance deteriorates which confirms your theory on this.
I have already upgraded the NAS to 5.3.13 and the health of my current HDD is all good.
I'm planning to introduce a 4TB HDD into the 4th bay to increase overall capacity.
Is there a calculator or method I can use to calculate the space I will be getting because currently I get approx 6TB with 4x 2TB HDDs in the NAS. So by introducing 4TB in 4th bay how much space would I finally have - guessing probably 8TB.
Thanks
- bedlam1Sep 20, 2018Prodigy
Installing just one 4TB wont do that, you will need 2 x 4TB to get 8TB.......check Here
- StephenBSep 21, 2018Guru - Experienced User
- Jan 17, 2024Retired_Member
