Unixed
Sep 24, 2012Aspirant
Readynas NV+ V2 hangs with write or read #19508960
I just purchased a Readynas NV+ V2 hangs a couple of days ago. I installed RAIDar 4.3.4 and set up the Readynas NV+ V2 with firmware 5.3.6. I have 3 matching Seagate 1TB hard drives. I allowed the ...
mdgm-ntgr
Sep 24, 2012NETGEAR Employee Retired
Could you open a support case and post your case number?
Please download your logs (via the Dashboard click Configure and go to System > Info > Logs > Download Logs) and have the zip file ready to submit. If the case you open is an online case at my.netgear.com you can attach your logs to your case.
After downloading your logs and while you wait for a response from support you may wish to run a few passes of the memory test and also the "Disk Test" boot option: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
