Unixed
Sep 24, 2012Aspirant
Readynas NV+ V2 hangs with write or read #19508960
I just purchased a Readynas NV+ V2 hangs a couple of days ago. I installed RAIDar 4.3.4 and set up the Readynas NV+ V2 with firmware 5.3.6. I have 3 matching Seagate 1TB hard drives. I allowed the ...
Unixed
Sep 27, 2012Aspirant
I think I may have discovered a fix. I re-flashed the unit with the same version of firmware that was loaded at the factory 5.3.6. I then conducted a factory reset on the unit. As of right now I was able to successfully transfer 98GB successfully.
I will continue to monitor. I noticed that the firmware 5.3.6 was released to the public on the 10th of September. I am not too sure on how long it takes to build and deliver to the store, but I am wondering the factory is using a different firmware build. I purchased this unit on the 24th of September.
