Lestrad
Jun 10, 2019Aspirant
ReadyNAS nv+ won't power up after outage. Power Supply Problems?
Hello My ReadyNAS NV+ (Product: ReadyNASRND4000, Serial Number: 23J3027700C11) was originally purchased in November 2010. In June 2016 I had a problem with the power supply: The NAS wouldn't start u...
- Jul 09, 2019
Yup. You can test that it turns on the supply with it disconnected before you do it with it connected. You'll know the supply came on because the fan will run.
If it works, you likely won't want to leave it that way, but it's a way to get the data off the NAS.
Jun 11, 2019Guru - Experienced User
I don't think you'll be able to find the seasonic anymore.
There are a couple of options here:
http://www.evercase.co.uk/CompatibilityListReadynas.htm
Though the last two are quite expensive.
It's likely time to get a new NAS. You can jury-rig an ATX supply (running externally) to extract the data.
Support can also temporarily mount the data volume (Read-only) in a new ReadyNAS - though they will charge.
Sandshark
Jun 11, 2019Sensei
It does sound like it could be a problem with the +5VSB (5V standby) power that powers the power-on circuit and NIC.
- LestradJun 11, 2019Aspirant
Thanks! So you think a PSU replacement would put me back in business? As I said, the unit seems to work fine once it's powered up. Plus, as I mentioned above, a new NAS would be expensive for me.
