xlr8r
Jan 22, 2024Luminary
Readynas RNDP6000 (OS6) power cycling every 2 seconds following a area-wide power outage.
hi guys
hoping for any suggestions of where to start fault finding, to get my NAS to boot up ?
We had "that storm" yesterday and electricity to the whole area was off for 24 hours. When it came back on, the only thing not working was the NAS. I could hear it turning on and off quickly and the blue power led was going on and off as if power cycling as if not getting enough power...?
all i have done so far is disconnect the mains cable for a few mins, but this made no difference. Issue is the same.
many thanks
xlr8r wrote:
should I assume it's safe to test the main NAS motherboard using a standard 300w ATX PC power supply ?
Should be. See this old discussion thread:
It could be a failed power supply. This can be replaced.
I suggest unplugging it and removing the disks (labeling them by slot, so you know where they go). Then power up diskless, and see if you see the same behavior.
- xlr8rLuminary
ok thanks Stephen ill give that a go
i neglected to mention that the nas was operating on a UPS and would have shutdown when the battery got to 20%, does this have any bearing on the fault ?
- xlr8rLuminary
ok stripped the unit down removing the PSU for testing since it continued to exhibit the same fault with all drives removed.
on testing the PSU (with a PSU tester), only the 5v was present. 3v and 12v are dead rails.
looks like a replacement is needed. are there any good recommended alternative (or modded) PSU's I can tinker with ?
many thanks
