xlr8r
Jan 22, 2024Luminary
Readynas RNDP6000 (OS6) power cycling every 2 seconds following a area-wide power outage.
hi guys hoping for any suggestions of where to start fault finding, to get my NAS to boot up ? We had "that storm" yesterday and electricity to the whole area was off for 24 hours. When it ca...
- Jan 22, 2024
xlr8r wrote:
should I assume it's safe to test the main NAS motherboard using a standard 300w ATX PC power supply ?
Should be. See this old discussion thread:
Jan 22, 2024Guru - Experienced User
xlr8r wrote:
blue power led was going on and off as if power cycling as if not getting enough power...?
It could be a failed power supply. This can be replaced.
I suggest unplugging it and removing the disks (labeling them by slot, so you know where they go). Then power up diskless, and see if you see the same behavior.
xlr8r
ok thanks Stephen ill give that a go
i neglected to mention that the nas was operating on a UPS and would have shutdown when the battery got to 20%, does this have any bearing on the fault ?
- xlr8rJan 22, 2024Luminary
ok stripped the unit down removing the PSU for testing since it continued to exhibit the same fault with all drives removed.
on testing the PSU (with a PSU tester), only the 5v was present. 3v and 12v are dead rails.
looks like a replacement is needed. are there any good recommended alternative (or modded) PSU's I can tinker with ?
many thanks
- StephenBJan 22, 2024Guru - Experienced User
That should have provided some protection. Still a power surge might have reached the PSU when the power failed.
thanks
just to rule that out as well ?
thanks
