Lestrad
Jun 10, 2019Aspirant
ReadyNAS nv+ won't power up after outage. Power Supply Problems?
Hello My ReadyNAS NV+ (Product: ReadyNASRND4000, Serial Number: 23J3027700C11) was originally purchased in November 2010. In June 2016 I had a problem with the power supply: The NAS wouldn't start u...
- Jul 09, 2019
Yup. You can test that it turns on the supply with it disconnected before you do it with it connected. You'll know the supply came on because the fan will run.
If it works, you likely won't want to leave it that way, but it's a way to get the data off the NAS.
Lestrad
Jun 18, 2019Aspirant
Okay, I opened the case and tested the power supply, and all voltages are in line with the specs. So it looks like it's not the PSU after all.
I removed the top cover (exposing the memory slot) and sniffed and there is a slight burned smell. So I suppose some other component could be bad. But it seems odd that the unit did started up and stayed on line long enough to complete a re-synch.
I'm open to any suggestions.
