Kardano's avatar
Kardano
Luminary
Nov 18, 2018
ReadyNAS NVX boot and restart problem
Hello,   I gety my hands on old NVX unit. It is RNDX4250, FW 4.2.31. I inserted my 4 WD20EFXR disks.   Unit has a strange behaviour/error on 2 occasions:   1. When i get to restart unit (...
  • StephenB's avatar
    Nov 18, 2018
    Kardano wrote:
    If i use this specific (this piece) disk tray, No mather what position, no mather which disk, unit stuck before booting until shut down and reseating of tray is done.
    Is it possible that that tray is bad somehow?
    This isn't a symptom I've seen posted before, but it does sound like something isn't quite right with the disk tray.  I'm not sure exactly what would cause this particular symptom - though it would somehow linked to not having a solid connection to the SATA or power connector on the disk.
    The part number is RND4TRAY1-10000S, which might help googling.  They are hard to find. Newer trays have a square latch button, the older design with the circular button tended to jam.  Both will work.
    Also, sometimes you will see older ReadyNAS sold for parts.  So perhaps look for that also.  Note that rackmount ReadyNAS use a different tray design, so those won't work in your NVX.  But Pro, Ultra, Duo v1, Duo v2, NV+ v1, NV+ v2 trays will all fit.
ProSupport for Business
