SteveSyd66
Feb 26, 2012Aspirant
ReadyNAS NVX Disc Expansion Fail - RESOLVED BY NETGEAR
Summary The NVX had 3 x 2TB drives (3.6Gb space + Redundancy) Hot swapped a new 2Tb Drive (Same make maodel as previous 3 - WD2002FYPS RE-4 GP) Fourth Disk Recognised BUT vlume not expanded -...
mdgm-ntgr
Feb 26, 2012NETGEAR Employee Retired
What version of RAIDiator are you running?
Please try a reboot, wait 5-10 minutes and if expansion hasn't started, try another reboot. Expansion should then take place.
You should not see that message on a 4-bay NAS as dual-redundancy is not an option.
Welcome to the forum!
SteveSyd66 wrote: Configuration: RAID Level X-RAID2, 4 disks
Status: Redundant
SteveSyd66 wrote:
{Next added drive: Will be used to expand volume
Will be used to add dual redundancy } Note text in brackets copied accross BUT IS NOT APPEARING ON RAIDIATOR SCREEN!!! These blind messages probably explains why the volume has not expanded - BUT since these text messages and probably option boxes are not on screen - how do I FIX?
