yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello,
I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the ESXi can see all the LUNs but once I try to write or create a VM it just keeps showing In Progress but after a while it says Unable to access file xxx/xxx.vmxf. I have two other ESXi 4.1 on the ReadyNAS volume and they are working perfectly fine. Furthermore, when this ESXi 5.0 machine was ESXi 4.1 it was also working fine together with the two other machines on the same VMFS volume.
I tried adding a new LUN using VMFS v5 and it seems to be writing fine but here I only have one machine accessing the VMFS LUN.
Some errors I see on ESXi 5.0 for the VMFS 3.46 volume are as follows:
2011-08-27T15:28:49.063Z cpu0:2056)ScsiDeviceIO: 2305: Cmd(0x412400749ac0) 0x93, CmdSN 0x226 to dev "naa.60014052e2962c00248d003000000000" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x24 0x0.
2011-08-27T15:28:49.083Z cpu0:2056)NMP: nmp_ThrottleLogForDevice:2318: Cmd 0x93 (0x412400749ac0) to dev "naa.60014052e2962c00248d003000000000" on path "vmhba34:C0:T1:L1" Failed: H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x24 0x0.Act:NONE
2011-08-27T15:28:49.099Z cpu0:2056)ScsiDeviceIO: 2305: Cmd(0x412400749ac0) 0x93, CmdSN 0x226 to dev "naa.60014052e2962c00248d003000000000" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x24 0x0.
2011-08-27T15:28:49.103Z cpu0:2056)ScsiDeviceIO: 2305: Cmd(0x412400749ac0) 0x93, CmdSN 0x226 to dev "naa.60014052e2962c00248d003000000000" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x24 0x0.
2011-08-27T15:28:49.123Z cpu0:2056)ScsiDeviceIO: 2316: Cmd(0x412400749ac0) 0x93, CmdSN 0x226 to dev "naa.60014052e2962c00248d003000000000" failed H:0x3 D:0x0 P:0x0 Possible sense data: 0xb 0x24 0x0.
2011-08-27T15:28:49.123Z cpu6:2177)ScsiDeviceIO: 2949: CmdSN 0x24f to device naa.60014052e2962c00248d003000000000 timed out: expiry time occurs 1ms in the past
2011-08-27T15:28:49.123Z cpu6:4241)FS3DM: 2427: status Timeout zeroing 1 extents (65536 each)
2011-08-27T15:28:49.123Z cpu6:4241)J3: 2601: Aborting txn (0x410018c24c50) callerID: 0xc1d00006 due to failure pre-committing: Timeout
2011-08-27T15:28:49.123Z cpu6:4241)Fil3: 13341: Max timeout retries exceeded for caller Fil3_FileIO (status 'Timeout')
2011-08-27T15:28:49.123Z cpu6:4241)BC: 4347: Failed to flush 1 buffers of size 8192 each for object '1' f530 28 3 4e04f371 46875229 1c00457f dca691c0 3401444 13 0 0 0 0 0: Timeout
Does anyone have any idea of why this is happening on the ReadyNAS NVX with ESXi 5.0 or whether the ReadyNAS isn't really compatible with ESXi 5.0?
Thanks,
Thanks,
- gavindAspirantHas anyone heard anything if there will be a new version coming out yet?
