Tim99
May 28, 2018Aspirant
readynas offline but still visible in explorer
hello.
my readynas drive is visible and accessible a a mapped drive [Z]. but does not connect using my firefox browser .` it just says it is offline. firmware is 6.2.2 and pc is windows 7 pro.
Tim99
thanks for your detailed response, Bedlam1, the oldest available is 6.4.2 arm, so i will try that, though i'm surprised it wont update to the latest version straight away - poor programming perhaps ?
i vaguely recall seeing firmware upgrades yesterday, so if i can find it agaain i'll give it a try!
I will keep this thread informed.
cheers
tim.
May 28, 2018Guru - Experienced User
No, 6.2.5 is still out there : https://kb.netgear.com/29498/ReadyNAS-OS-Version-6-2-5-RN102-RN104-Only
But I think you should resolve your issue before trying to upgrade your firmware. Otherwise you risk making it worse.
I'm a little confused on your current access
- Can you access the NAS shares through file explorer?
- Can you access the NAS web ui with https://nas-ip-address/admin
If you can access the shares, then I agree with bedlam1 that you should make a backup before you do anything else.
- Tim99May 31, 2018Aspirant
(been away)
back again. have got the 6.2.5 img file ready to upload, (thankyou for link StephenB) but even though the folders & files are clearly accessible via windows explorer, when I try to upload the img file via the admin/browse screen, it immediately says 'ERROR-SERV-UNREC' then tries to reconnect with the comm lost screen.
i have rebooted it with no effect.
the nas drive IS my backup, and the files are all presently accessible, but i do actually want to delete a few old backups, which i can do in explorer, but they must be going into a hidden recycle bin, as the free space is staying the same !
is it worth trying to reset to factory default ? or will that delete all my data ?
am sorely tempted to buy a different make and just copy it all across and send this little beggar to the scrapheap !
thanks for listening.
tim
- StephenBMay 31, 2018Guru - Experienced User
A factory reset will delete your data. So if you want to keep it, you will need to back up the files to external storage. Since the web ui is not responding, then the best way to do that is to copy it over the network (either to internal disks on the PC or USB drives connected to the PC).
A factory reset (after a firmware upgrade) would also give you better performance. Netgear has made some adjustments to the file system setup that help with performance, but they only come into play with a fresh installation. So if you go down this path, I suggest doing the reset, then upgrading the firmware and doing a second reset.
Then you might have enabled snapshots on the shares. However, "free space" is a slippery concept in the BTRFS file system that the NAS uses, and there were some bugs in the way space was reported in some of the early firmware. I'm not sure if they were with your particular firmware or not.
It's up to you of course. Note I don't work for Netgear (this is a community forum). It's pretty clear that you have more-or-less ignored your NAS (otherwise the firmware would be much newer). That's not good practice with any NAS from any vendor.
You do need to keep log in from time to time, update the firmware, etc. There are also maintenance tasks that can be scheduled in the current OS-6 firmware that can help keep the file system on the NAS in good shape, and give you earlier warning on disk issues, etc. Setting up the email alerts on the NAS is also a good idea, as they can provide warnings when things aren't right.
In general - RAID is not enough to keep your data safe. It is safer than not using RAID, but the main benefit is that your data is preserved during routine disk replacements and volume expansion. You can still lose data as a result of device failures, user errors, malware on your network, theft, etc. Anything you care about should be backed up to another device. This applies to all vendors and models.
Your NAS was entry-level (and Netgear's current entry-level model is the more capable RN21x series). However, it should still serve well as backup storage.
