Lennardo
Feb 11, 2016Tutor
ReadyNAS OS 6.4.2 => sometimes lost connection
Hallo, i've installed new OS on my 314 and get faster directory-access. all others seems the same, excep transferrate (little bit lower). But yesterday 5x and today 2x i lost connection to NAS fr...
- Feb 11, 2016
You can drop back to 6.4.0 easily - just download the zip here:http://kb.netgear.com/app/answers/detail/a_id/29938/~/readynas-os-version-6.4.0 Extract the image from the zip, and then use the manual install button on system->settings.
Its hard to go further back (and it would require a factory reset among other things).
mdgm-ntgr
Feb 11, 2016NETGEAR Employee Retired
Before you downgrade (if you wish to) can you send in your logs (see the Sending Logs link in my sig)?
- LennardoFeb 11, 2016Tutor
you got mail.
Thanks for your help.
Tschüß
- mdgm-ntgrFeb 11, 2016NETGEAR Employee Retired
Your data volume is extremely full (94%) and you set this up back on 6.1.2.
I would suggest freeing up some space on this NAS (e.g. by deleting some older snapshots). Ideally volume usage should be kept to under 80%.I can see you have a lot of snapshots and a lot of metadata. What kind of data are you storing on this NAS?
- JennCFeb 12, 2016NETGEAR Employee Retired
Hello Lennardo,
Here is an article in case you need steps how to delete old snapshot: How do I delete snapshots using the recovery mode on my ReadyNAS OS 6 storage system?
Delete only the ones you do not need, the snapshots indicate the date they were taken.
