Beeldbuisje
Mar 14, 2023Guide
iPadOS devices sometimes looses connection with RBR50
Having a strange issue at home and don't know if it's related to my iPad or my RBR50.
I own an iPad 8, my wife a 7 and daughter an old Air 2.
All three iPads are always at home, connected to the RBR50 (and two satellites)
My 8 sometimes looses connection. Wifi symbol is active and has full reception, but there's no internet connection.
Switching to Airplane mode and back solves the issue for a few days.
Already did a complete system wipe, let everything standaard. After one week the same issue.
Not my wife, nor my daughter have the same issue with their iPads.
Router is setup as accespoint to my ISP, Telenet Belgium.
Is this a known problem, with the RBR50?
thanks
Gert
I indeed switched on the data counter on the RBR. I wasn't aware about the issue around it and it gave me a crazy problem.
I think this topic can be closed. I bought a new iPad Air 2022 and for the time being, this device doesn't gives problems.
In the future I think the old iPad will be used as a central homekit control panel and will be continuously on the charger.
In the mean time, Apple released iPadOS16.4.1. I read somewhere on reddit this could solve some connection issues. Further experiments are necessary.
Be sure that any WiFi Private IP address is disabled on Apple mobile devices if present:
Doesn't need to be enabled while at home.
If other Apple devices are working and the one particular one isn't, maybe something with the device rather than Orbi. Would be something to contact Apple about.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.What Firmware version is currently loaded?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Wow, a lot of possible tips...
I asked it to Apple and Apple communities before I posted here. They also gave me the clue to turn off the private network option. I also did this, but it didn't work. After that, I did the complete wipe of the tablet, but the "private" function was enabled again. So this is disabled now.
No free time to check all those things now. Will be something for next Sunday. I'll report back later.
thanks so far!
Good, past weekend I had plenty of time to do some experiments and after doing those, I'll try to answer.
First things first, after posting my previous post, I connected the iPad to the wifi of my isp modem. No internet loss at all. Another positive point: my iPad's battery life has a huge increase when connecting to the isp modem. Normally the battery is empty after 5-6 days. Now, after one week, it's still on 60%. So the problem is for sure related to the Netgear.
I'll try to answer on the post of 03-14
I did a software upgrade to the last version available here on this forum. Upgraded successful my RBR and two RBS.
Did a factory restore, so the RBR is setup as a router now and not as an accesspoint. Except my login data and Wifi name and password, I let everything by default.
I did this Sunday morning, Monday morning again, battery drain on the iPad and no internet, but still reception.
Except the wifi signal of the isp modem there's no other wifi signal in my house. Switching off the wifi of the isp doesn't solve it.
Channels are on auto now, before the reset and before my first post, I already tried to switch them. Tried 1 and 11, but no succes. I had 36 on 5GHz.
house of 328sq ft. Around 25ft. between the satellites and router. But also a ceiling with ferroconcrete between 2 satellites.
After a factory restore of the router, I restarted everything as you advised.
I can try just one thing: place the iPad in a room (cellar) with absolutely no reception of the satellites.
"328sq ft" is this correct?
What happens if you turn OFF the RBS and run just the RBR alone with the pad?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What generation is this pad and iOS version thats loaded?
Did you disable WiFi Private IP address on the pad?
- KevinLiTNETGEAR Moderator
Hello Beeldbuisje,
Welcome to the NETGEAR Community!
I understand that you would like to optimize your network coverage using your Orbi Mesh System. The best placement practice for the Orbi Mesh System is to keep the router (model number: RBR) in the middle of the network between the two additional satellites.
Please navigate to the following link for Orbi placement reference:
Where should I place my Orbi satellite? | Answer | NETGEAR Support
Best,
Kevin
Community Team
Hello Beeldbuisje ,
Thank you for your post!
I understand that you are having issues with connections between your Orbi network and iOS / IPadOS. This could be due to the privacy feature added to those devices in the recent updates. Please turn off your private IP address if you are using an iOS / iPadOS device.
To turn off the Private IP address please follow the directions listed below:
Open "Settings"
"Wi-Fi"
Select the "i" icon next to your connected network
Toggle off "Private Wi-Fi Address"
Best,
Kevin
Community Team
KevinLiT wrote:Please turn off your private IP address if you are using an iOS / iPadOS device.
pfff, this makes no sense.
I'm very happy people trying to help me, but when something already mentioned and answered many posts before, it's not necessary to repeat al those things again and again.
I just wanna know one thing: why should I not place the RBR into the cellar when my satellites are on ground and first floor and hardwired...
