Lennardo
Feb 11, 2016Tutor
ReadyNAS OS 6.4.2 => sometimes lost connection
Hallo, i've installed new OS on my 314 and get faster directory-access. all others seems the same, excep transferrate (little bit lower). But yesterday 5x and today 2x i lost connection to NAS fr...
- Feb 11, 2016
You can drop back to 6.4.0 easily - just download the zip here:http://kb.netgear.com/app/answers/detail/a_id/29938/~/readynas-os-version-6.4.0 Extract the image from the zip, and then use the manual install button on system->settings.
Its hard to go further back (and it would require a factory reset among other things).
mdgm-ntgr
Feb 11, 2016NETGEAR Employee Retired
Before you downgrade (if you wish to) can you send in your logs (see the Sending Logs link in my sig)?
Lennardo
Feb 11, 2016Tutor
you got mail.
Thanks for your help.
Tschüß
- mdgm-ntgrFeb 11, 2016NETGEAR Employee Retired
Your data volume is extremely full (94%) and you set this up back on 6.1.2.
I would suggest freeing up some space on this NAS (e.g. by deleting some older snapshots). Ideally volume usage should be kept to under 80%.I can see you have a lot of snapshots and a lot of metadata. What kind of data are you storing on this NAS?
- JennCFeb 12, 2016NETGEAR Employee Retired
Hello Lennardo,
Here is an article in case you need steps how to delete old snapshot: How do I delete snapshots using the recovery mode on my ReadyNAS OS 6 storage system?
Delete only the ones you do not need, the snapshots indicate the date they were taken.
- LennardoFeb 12, 2016Tutor
Hallo,
mdgm wrote:Your data volume is extremely full (94%) and you set this up back on 6.1.2.
not 6.1.2, i want to go back to 6.4.0
This NAS is storage for some families in our house. It contain a Time Machine (1,5TB), Photos(1,5TB), Office-data (doc, xls, ...), Music and some EyeTV-achives (films and TVshows). These Films and TVshows are the biggest part with around 4TB of using space (and the easiest way to clean up).
I will get the usage below 80% but i think this wont fix the connection problem. Maybe this bring back a bit of speed, right?
Thank you
