Lennardo
Feb 11, 2016Tutor
ReadyNAS OS 6.4.2 => sometimes lost connection
Hallo, i've installed new OS on my 314 and get faster directory-access. all others seems the same, excep transferrate (little bit lower). But yesterday 5x and today 2x i lost connection to NAS fr...
- Feb 11, 2016
You can drop back to 6.4.0 easily - just download the zip here:http://kb.netgear.com/app/answers/detail/a_id/29938/~/readynas-os-version-6.4.0 Extract the image from the zip, and then use the manual install button on system->settings.
Its hard to go further back (and it would require a factory reset among other things).
Feb 12, 2016Guru - Experienced User
JennC wrote:
Delete only the ones you do not need, the snapshots indicate the date they were taken.
Usually you won't gain any space unless you delete the oldest. So you need to work oldest->newest. Also, the space savings don't always show up right away.
Lennardo
Feb 12, 2016Tutor
Hallo,
It would be great to know which snapshot need how much space. So i know in advance how much i can free or which shapshot is the efficientist to delete.
Thank you all
