firerain
Nov 09, 2016Tutor
ReadyNAS OS 6 Voltage probing
Hey guys! I was wondering, how does RNOS get voltage info. I'm getting an e-mail from time to time, informing me that the voltage in enclousure is lover than 12V. I want to get the information by...
- Nov 09, 2016
We are using libsensors directly. The sensors command will work if you install the appropriate package (lm-sensors).
c3po
Nov 09, 2016NETGEAR Expert
Which model is this? Is disk spin down enabled? Does warning timing have certain pattern? For example, if disk spin down is enabled, does warning ususlly come when disks wake up after long idle? What is warning reading ( < 10.8V ?) Thanks.
