firerain
Nov 09, 2016Tutor
ReadyNAS OS 6 Voltage probing
Hey guys! I was wondering, how does RNOS get voltage info. I'm getting an e-mail from time to time, informing me that the voltage in enclousure is lover than 12V. I want to get the information by...
- Nov 09, 2016
We are using libsensors directly. The sensors command will work if you install the appropriate package (lm-sensors).
Skywalker
Nov 09, 2016NETGEAR Expert
firerain
Nov 10, 2016Tutor
Yeah, after posting this message, I came upon this thread. Conclusion was simple: if there are sensors configs, then it has to be present. I've searched whole system and found libsensors, so the answer was quite obvious.
Anyway, thank you for answering :-) If there are libraries, I might try to use them instead of installing binaries.
c3po, this is a problem of my PSU. I have made a UPS-like buffer supply, which I mentioned in my previous thread. I've put a digital voltmeter in it to keep track of voltage being supplied. It's strange, because I'm getting those messages almost daily - actually, without any reason. The lowest voltage reported was 10.61V and I have never seen it to drop below 11.8V on voltmeter (even at the time the email was sent). Thats why i want to record the values in log.
