Hernexto
Nov 29, 2017Star
ReadyNAS OS6 nightly backup schedule
Hi! On my previous ReadyNAS pro 4 I could use full night schedule: 19pm to 4am But on ReadyNAS OS6 (currently 6.9.0) doesn't allow me to do this. My RSYNC backup need to run for hours at night (...
JohnCM_S
Nov 30, 2017NETGEAR Employee Retired
Hi Hernexto,
You can also setup a schedule for your Rsync backup on the ReadyNAS OS6. You may check this link on how to configure the backup schedule.
Regards.
JohnCM_S
NETGEAR Community
- HernextoDec 01, 2017Star
Sorry but I'm already using that method, and that's the point:
It doesn't allow to specify an initial hour greater than the ending one.
- StephenBDec 01, 2017Guru - Experienced User
That time range isn't when the backup can run - it's when the backup is allowed to start. Once started it runs to completion.
So the restriction isn't as big a problem as you are thinking.
