jcastrojjc
Feb 17, 2013Aspirant
ReadyNas Pro - Dual Redundancy
Hello All! New to the Forum. Was hoping someone can help me out. I have a ReadyNas Pro Edition RAIDiator 4.2.22 and just swap all 6 Hard Disks (2TB Western Digital WD20EFRX). I want to get away fro...
mdgm-ntgr
Feb 17, 2013NETGEAR Employee Retired
No, what is the volume capacity shown in Frontview under Volumes. Is your volume C about 7TB in capacity or 9TB?
If you are using dual-redundancy it should say so. If you did a factory default with 6 drives installed it should have configured your unit to use dual-redundancy.
