Chels_P
Jun 14, 2011Aspirant
ReadyNAS Pro - file/folder access permissions
Hi everyone, I've contacted Netgear support about this issue but they are too slow so I thought I'd try my luck here. I work for an IT management company and I manage the ReadyNAS Pro for one of...
Klayson1
Jun 15, 2011Aspirant
The way different apps handle files does make sense and explains why some files change and others do not. As for the everyone permissions set to read/write, all of our users are in the same primary group so we should not see that issue. However, it is good to know about it so that if we see any problems, we can modify our configurations.
Thanks for the info :D
