Chels_P
Jun 14, 2011Aspirant
ReadyNAS Pro - file/folder access permissions
Hi everyone, I've contacted Netgear support about this issue but they are too slow so I thought I'd try my luck here. I work for an IT management company and I manage the ReadyNAS Pro for one of...
Chels_P
Oct 02, 2011Aspirant
ajsimon wrote: Those of you monitoring this conversation...
I just updated to the latest (non-beta) firmware 4.2.19. On a first test, this seems to have fixed the problem. I was able to create a folder on a share from "computer A" logged in as myself. I then added a text document to that folder from "computer B" logged in as my wife. I was able to modify and save that file from "computer A," still logged in as myself.
Previously, under 4.2.17, I would get "access denied" messages when trying to modify a file/folder as any user other than that file/folder's creator (which was NOT the intended behavior on a family share!).
I will do some more testing and post the folder settings later... but for those of you who have been struggling with this (at least in a Windows environment), I recommend the upgrade to 4.2.19.
-A.J.
We too recently upgraded our problematic NAS to the latest firmware, 4.2.19, over a week ago and so far no one's been having any problems. I believe this has probably fixed the issue, however am going to keep an eye on it for a wee bit longer just in case.
