dawn1
Sep 03, 2013Aspirant
ReadyNAS Pro + CISCO EPC3925 -> slow transfer speeds?
I have recently purchased Netgear ReadyNAS Pro 4 to use as an all-round storage. Everything is working fine, but I am getting disappointed with the transfer speeds. On CIFS or iSCSI reads/writes I onl...
mdgm-ntgr
Sep 03, 2013NETGEAR Employee Retired
Does your PC and router/switch support Jumbo Frames and if so, have you enabled them on that? How does the performance compare when Jumbo Frames are disabled?
Are the drives still syncing (this is done after a factory default to setup the RAID syncing the drives sector by sector) or is the volume redundant?
