RDenben
Dec 10, 2014Aspirant
ReadyNAS Pro 2 - blue light keeps blinking
I have a ReadyNAS Pro 2. Everything was working fine until I tried to reboot. Now, on reboot, I get a solid blue light that turns flashing. The flashing light continues flashing and does not stop. R...
vandermerwe
Dec 11, 2014Master
The OS reinstall preserves data and is straightforward. It's certainly less risky than some of the things you've already tried like pulling disks and booting.
You should test all your disks with vendor tools as well.
