RDenben
Dec 10, 2014Aspirant
ReadyNAS Pro 2 - blue light keeps blinking
I have a ReadyNAS Pro 2. Everything was working fine until I tried to reboot. Now, on reboot, I get a solid blue light that turns flashing. The flashing light continues flashing and does not stop. R...
Dec 11, 2014Guru - Experienced User
Did you try directly accessing the NAS admin page using its IP address? Does it reply to ping?
Note the sentence on page 12:
Do you have a scratch disk you can try? If so, maybe power down, remove the two existing drives (labeling them by slow), then install the scratch. That should attempt a factory install - if it succeeds, then your chassis is fine. If the chassis has failed, then you are probably in a tough spot if you can't reinstall OS 4 somehow.
Your hardware manual is here: http://www.readynas.com/download/docume ... pril11.pdf
RDenben wrote: I also rebooted with "Disk test". The information indicator in RAIDar indicated the disk test was running, and then after a long time RAIDar returned to displaying the OS information. How do I know the result of this "disk test"?...
Disk test. Performs an offline full disk test. This can take 4 hours or more, depending on the size of your disks. Any problems are reported in the RAIDar discovery tool.
