RDenben
Dec 10, 2014Aspirant
ReadyNAS Pro 2 - blue light keeps blinking
I have a ReadyNAS Pro 2. Everything was working fine until I tried to reboot. Now, on reboot, I get a solid blue light that turns flashing. The flashing light continues flashing and does not stop. R...
Dec 11, 2014Guru - Experienced User
It's good that you can access the files. That also means that your chassis is ok - so there's no need to try a scratch drive.
If you don't have a backup, then you should make one right away.
After that, try connecting to the NAS web page using its IP address - https://nasipaddress/admin Let us know if that is still off line.
