RDenben
Dec 10, 2014Aspirant
ReadyNAS Pro 2 - blue light keeps blinking
I have a ReadyNAS Pro 2. Everything was working fine until I tried to reboot. Now, on reboot, I get a solid blue light that turns flashing. The flashing light continues flashing and does not stop. R...
RDenben
Dec 11, 2014Aspirant
StephenB wrote: By default it presents your windows logon.
RDenben wrote: Windows does not ask for credentials when I try to copy the files on the NAS. It just responds that "access is denied"
Try opening a cmd box (enter "cmd" in the bar in the start menu).
Thennet use * /deletewhere password is the NAS admin password. Also "data" is the default name of the data volume. If you named it differently, substitute the name you chose.
net use T: \\nasipaddress\data /user:admin password
That should mount the volume to the T drive letter on the PC.
I was able to delete the remote entries, but when trying to establish them with the "net use" command, Windows responded that "multiple connections to a server or shared resource....are not allowed" I verified that there are no entries when attempting to run "net use * /delete"
