Khalid2019
Nov 19, 2019Aspirant
readynas pro 2 - corrupt root
Hi I have readynas pro 2 , and the status corrupt root . I don't want to reset the device because I have data i don't want to lose . Also I try access to the device from the browser by using ip...
Nov 19, 2019Guru - Experienced User
You could try powering down the NAS, and booting up with only disk 2 in place. If that works, then immediately back up your data. Don't write more data to the NAS.
Khalid2019
Ok , I will try this solution and i will feed you back thank you for your reply
- Khalid2019Nov 19, 2019Aspirant
I also I take off the Hard disk from the readynas pro 2 and I insert in stata adapter .
And I connect the stata adapter to my laptop directly , the hard disk not appear in disk management i cannot see the hard disk- StephenBNov 19, 2019Guru - Experienced User
And I connect the stata adapter to my laptop directly , the hard disk not appear in disk management i cannot see the hard diskSo disk 1 appears to have failed. Do you have any idea when that might have happened?
Did the system boot without it? (leaving disk 2 in slot 2)?
For first question really , I don't know why it's happen the problem in hard disk number one .
For the second question , I will try boot without hard disk number one (leaving disk 2 in slot 2) , I will feed you back .
