Khalid2019
Nov 19, 2019Aspirant
readynas pro 2 - corrupt root
Hi I have readynas pro 2 , and the status corrupt root . I don't want to reset the device because I have data i don't want to lose . Also I try access to the device from the browser by using ip...
Khalid2019
Ok , I will try this solution and i will feed you back thank you for your reply
Khalid2019
I also I take off the Hard disk from the readynas pro 2 and I insert in stata adapter .
And I connect the stata adapter to my laptop directly , the hard disk not appear in disk management i cannot see the hard disk
- StephenBNov 19, 2019Guru - Experienced User
And I connect the stata adapter to my laptop directly , the hard disk not appear in disk management i cannot see the hard diskSo disk 1 appears to have failed. Do you have any idea when that might have happened?
Did the system boot without it? (leaving disk 2 in slot 2)?
- Khalid2019Nov 19, 2019Aspirant
For first question really , I don't know why it's happen the problem in hard disk number one .
For the second question , I will try boot without hard disk number one (leaving disk 2 in slot 2) , I will feed you back .
- Khalid2019Nov 20, 2019Aspirant
Hi
I tried the solution you write up , but I face the same problem is there another solution ?
