andy-b
Jun 26, 2016Aspirant
ReadyNAS Pro 2 - no access
Hi, I have suddenly lost access to the data on my ReadyNAS Pro 2. I can log in via the Web admin interface, but all file sharing protocols are off and can not be turned on. The situation seems simi...
- Jun 26, 2016
Well, the original post was suggesting that you use the procedure here: http://onlyblueatwork.wordpress.com/2012/12/04/net
gear-readynas-access-recovery/ followed by mdgm's suggestions after you clean the OS partition
# cd
# sync
# umount /mnt
# mdadm --stop --scando you have a backup?
andy-b
Stephen,
I have access to WebUI but actions are not working. Your link is the one I was using. It reports "Update file is not valid for this architecture."
/Andy
Jun 26, 2016Guru - Experienced User
# cd
# sync
# umount /mnt
- andy-bJun 26, 2016Aspirant
The boot to Tech support option worked for me. And I can now see all my data.
Thanks.
/Andy
(I had a backup but it was older than it should have been :-)
