macgyom
Nov 30, 2015Aspirant
ReadyNas Pro 2 (RNDP2000) failed to boot
Hi all, After an update (4.2.27 -> 4.2.28) My ReadyNas Pro 2 doesn't boot anymore. I have tried to fully erase (low level format) my 2 HDD 1To of my Nas, then put them in my readynas & boot into...
- Dec 01, 2015
As I suspected a file on the internal flash was corrupt. I have fixed this.
This is a problem that can occur in some cases but it would only be an issue when doing a factory default.
BrianL2
Nov 30, 2015NETGEAR Employee Retired
Hi macgyom,
Try to set it up and connect the device directly to your PC. Also, if you have a spare drive we could further isolate if the issue is with the hard drives or with the ReadyNAS.
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
Dec 01, 2015NETGEAR Employee Retired
