cory7761
Jul 01, 2016Aspirant
ReadyNAS Pro 2 Slow write speeds
Hello everyone. I hope someone on here can help me. I'll try to keep this short. I bought my Readynas Pro 2 about 5 years ago. It was the diskless model. I put 2 7200rpm 3TB seagate drives in it. I ...
Jul 01, 2016Guru - Experienced User
It's not the mismatch in the drive RPM (as you have already concluded).
Are you using both ethernet connections or just one? How full is the disk volume? what firmware are you running?
It would be good to try a direct-connect test (directly connecting the NAS to your PC NIC card). You need to temporarly assign a static IP to the NAS.
-If the pro is using DHCP, then it will use 192.168.168.168 during the direct connect
-set the PC to 192.168.168.100 with subnet mask 255.255.255.255
-access the nas via \\192.168.168.168 (not by name).
NAStester is a convenient tool for testing speeds: http://www.808.dk/?code-csharp-nas-performance
- cory7761Jul 01, 2016Aspirant
I am only using one ethernet connection but that is what I have always done. The disks are 51% full. Firmware version RAIDiator 4.2.28. I will try the direct connect when I get home if you think it will be beneficial. If I can read at over 100MBps then I should theoretically be able to write that fast. Right? Right now I have a router and a switch between my computer and the NAS. Everything is hard wired and all ports are gigabit.
Thank you for your help.
Cory
- StephenBJul 01, 2016Guru - Experienced User
Good. That rules out any issues due to nic bonding and volume fragmentation.
Writes are inherently slower - the data needs to be written to both disks. Though the difference should be slight. Smallnetbuilder's performance tests are here: http://www.smallnetbuilder.com/nas/nas-reviews/31471-new-to-the-charts-netgear-readynas-pro-2?showall=&start=1
That's useful to know. The direct-connect will let us know if the router, switch, or cabling between them are slowing down the writes (or not).
