cory7761
Jul 01, 2016Aspirant
ReadyNAS Pro 2 Slow write speeds
Hello everyone. I hope someone on here can help me. I'll try to keep this short. I bought my Readynas Pro 2 about 5 years ago. It was the diskless model. I put 2 7200rpm 3TB seagate drives in it. I ...
cory7761
I am only using one ethernet connection but that is what I have always done. The disks are 51% full. Firmware version RAIDiator 4.2.28. I will try the direct connect when I get home if you think it will be beneficial. If I can read at over 100MBps then I should theoretically be able to write that fast. Right? Right now I have a router and a switch between my computer and the NAS. Everything is hard wired and all ports are gigabit.
Thank you for your help.
Cory
Jul 01, 2016Guru - Experienced User
Good. That rules out any issues due to nic bonding and volume fragmentation.
Writes are inherently slower - the data needs to be written to both disks. Though the difference should be slight. Smallnetbuilder's performance tests are here: http://www.smallnetbuilder.com/nas/nas-reviews/31471-new-to-the-charts-netgear-readynas-pro-2?showall=&start=1
That's useful to know. The direct-connect will let us know if the router, switch, or cabling between them are slowing down the writes (or not).
