Sifter's avatar
Sifter
ReadyNAS Pro 4 slot 3 is not powered
Installing a Pro 4, and have a single 320gig drive for testing that Ive installed by itself. Im testing to make sure each slot is good on the unit. Each time I move the drive to a new slot, I take the unit through a full factory reset, and install the software/firmware to the drive. Im able to then login via HTTP and use navigate the unit as normal. The drive and unit install just fine on every slot except for slot 3. Slot 3 doesnt appear to be getting any power to it.
When the drive is in slot 3, after the factory reset and power on, the screen on the front says "No disks detected!"
Running RAIDiator 4.2.22.
Is there any other troubleshooting I can do to perhaps get slot 3 going?
  • Send me a PM with a link to the copy of your logs and I will take a look for you.
    If your channel 3 is not working, then it is likely you will need to RMA the chassis.
  • So I synced a new drive thinking maybe it was the drive. SMART is complaining about a ton about errors.
    Model: ST3000DM001-1CH166
    Serial: W1F1MAPG
    Firmware: CC24
    SMART Attribute
    Spin Up Time 0
    Start Stop Count 8
    Reallocated Sector Count 0
    Power On Hours 3
    Spin Retry Count 0
    Power Cycle Count 8
    Runtime Bad Block 7
    End-to-End Error 0
    Reported Uncorrect 0
    Command Timeout 120
    High Fly Writes 0
    Airflow Temperature Cel 36
    G-Sense Error Rate 0
    Power-Off Retract Count 3
    Load Cycle Count 12
    Temperature Celsius 36
    Current Pending Sector 0
    Offline Uncorrectable 0
    UDMA CRC Error Count 2435
    Head Flying Hours 65446711656451
    Total LBAs Written 626559480
    Total LBAs Read 444438093
    ATA Error Count 0
ProSupport for Business
