Singularity
Dec 28, 2013Tutor
ReadyNAS Pro 6 - Best Expansion Path
My ReadyNAS Pro 6 is currently configured as follows Bay 1: 1Tb (931 allocated) Bay 2: 1Tb (931 allocated) Bay 3: 1Tb (931 allocated) Bay 4: 1Tb (931 allocated) Bay 5: 2Tb (1863 allocated) Bay...
mdgm-ntgr
Dec 28, 2013NETGEAR Employee Retired
Would be best to do a factory default with the new disks in place.
Say your current disks were installed when you last did a factory default you can't expand past 3683 GB + 8TB. You also can't expand past a hard limit of 16TB.
